1 - 15 of 15 Posts
85 Runner 4 sale SOLD
okay guys, this is just the body,camper and frame.interior wise you get dash and a non SR5 cluster and ecu with back seat.NO engine harness! 500 obo
trades welcome,possible delivery
dang, just bought a 90! would of snatched this one up in a heart beat. do you have a 22re ac compressor bracket by chance?
I was going to pm you and let you know the other guy backed out and it was yours.But then I saw you picked up a 90,is yours a 2 or 4 door? I will check on the bracket.
thanks. let me know on that bracket.
it's a 4 door. I can't believe no one is jumping on this. i would have bought it in a heart beat.
thanks,
steve
are you converting your runner to a 4 banger? I am thinking about doing a SAS on a newer runner, or get one for DD and deck it out.
The runner is already sold, I loaded it up this morning for delivery.
cool. i'm putting the body atop my frame/motor. But i wanna use the newer ac compressor/lines. Already pulled the motor wiring harness and all the stuff that attaches to the frame. leaving the body harness in. Just gotta pull the doors and interior so i can duraline (cheap autozone bedliner) the inside. After that i guess it's pull the body's, swap, and weld on some new body mounts. I'll probably cut the fenders alot considering my wheelbase is anywhere between 3-5" longer than the 4runners. I'm hoping i won't need a body lift.
hopefully it'll weigh about the same as my heavy ass flatbed and truckbox. if not, i might need to get the blower rebuilt so i can boost 10psi instead of the 4-5 that i am now...
but yeah, let me know on that 22re ac bracket, i'm also looking for the clutch/brake pedal bracket as well.
thanks
steve
Discussion Starter · #7 ·
I have a couple of brackets left over from my OBA conversions, just have to figure out which brackets are which. What year is you motor out of?
it's a 81' 22r. but i need the bracket for the later compressors that bolt to the bracket by 4 bolts. not the one that bolts parralel to the block.
ie
for that style of compressor.
i'm hoping the ac compressor brackets for the 22re and the 22r are interchangeable.
for the clutch/brake bracket i'm sure all years work.
Discussion Starter · #9 · (Edited)
okay, I know which one you want. I have two junk compressors that I have labeled to determine which bracket is needed.I ran into the mounting issue on an 84 xcab and 85 runner, 2 different compressors.But the mounts were interchangable if I recall correctly.It will be Thursday morning before I get back into the shop.
I may take the 2 V6 diffs and tranny off your hands.I have another 85 I am gathering pars for.
alrite, let me know. the auto or manual? if it's the auto, i'd have to pull it outta the truck... probably just pull the whole motor out of the 4runner and you'd have to take the rusty block too!
steve.
that'll work. do you have the brake/clutch bracket as well?
any luck with the a/c bracket?
thanks,
steve
cool. i may pull the motor/tranny this weekend depending if i'll have time to pickup my runner from the shop.
do you know if the 22r and 22re mounting points are the same?
steve
1 - 15 of 15 Posts
