1 - 3 of 3 Posts
Can be streetable but mostly just a wheeler. Carb is gummed up from sitting a year. Front axle still good although missing some wheel studs. Rear axle was welded up, didn't like it and blew something out of the back. Still drives in 2wd and locked up. Third is trashed I'm sure.
Engine:
SBC 307 block.
New rod and main bearings.
High volume oil pump.
New timing set.
350 heads. Heads were machined and new valve springs put on.
Lunati cam/lifters
Edelbrock 2101 manifold
Crappy headers. Garage fabbed exhaust.
Edelbrock 1406 carb
HEI distributor
Transmission:
Rebuilt TH350 with shift kit. Kit was setup for more holding torque.
Advanced adapters 350 to toyota case adapter.
New converter installed during swap.
Truck:
Rancho 3" leaf packs
Radiator/fans out of a 06 silverado rear mounted
16gal. Fuel cell in bed.
Home made cluster with gauges
Crossover steering conversion.
Included:
87 350 TBI engine ready to get machined.
New .030 pistons
New cam bearings
Front and rear corporate 10 bolt axles from a 82 K5
Uninstalled sliders
Every little odds and ends I can find.
$2000 for everything title in hand
Truck will not run twister.
1 - 3 of 3 Posts
