I just bought a super clean '96 4-runner for the wife to chase groceries and what not in.
It's a Two wheel drive with the 3.4 V6.
Every thing about this truck is like new, and it drives really great.
It only has one thing that needs fixing.
The tachometer.
When the motor is at idle, it indicates 1k. This seems normal.
At 70 MPH, the tach shows about 3k. I don't know if that's normal or not.
If you push the gas pedal to the floor, the tranny will down shift as expected and the truck accelerates like it should.
Here's the wierd part. When you make it run like this, the tachometer goes all the way off the scale. it goes down to what would be at least nine thousand RPMs if there were numbers down by the idiot lights!
Now, I'm pretty sure that the motor is not over-revving. I don't hear the stuttering sound of a rev limiter, and it doesn't sound like it's spinning too fast at all.
And I'm also pretty sure that 9k would scatter that baby all over the place.
The problem is the tach. It's a liar!
So...
Here's the question.
Have any of you guys seen this before?
Does anybody have any suggestions before I tear into this mother?
Thanks in advance for any help!
Fast Frank
The tachometer.
So...
Fast Frank
