1 - 14 of 14 Posts
White with black leather interior.
Pioneer AM/FM/CD
New carpet
Center console with ZJ shifters
Runs 7" of lift with Long arms up front, leaf packs in back. Long arms were installed spring 2005 and the LCA frame mounts are still there. Uses a 5" coil and 2" spacer up front.
Bumpers front and rear swing away were custom built and are 1/4" plate. Rear has tire carrier, antenna mount, and license plate mount with light.
Flares are 4 rear TJ's, Front fenders and flares are cut, I have them but the rears are Not installed.
There is a homemade snorkel mounted outside, but the piping is not complete to the airbox. I have fittings and pipe to complete the project that go with the jeep.
Tires are 33x12.50 TSL Radials on 15x8 white wagons. One does have a plug, but does not leak at all. Spare is 33x10.50.
As a knuckle over steering system and RE trac bar that was moved up and over to compensate for the steering geometry changes.
Engine was NEW in 2000, Chrysler remaned unit installed by Hanover Dodge/Jeep. It currently has approx 22k on the engine. Transmission and t-case were remaned and installed at same time.
Has an SYE in rear and cv driveshaft.
Rear disc brakes from ZJ and functioning e-brake.
Dual diaphragm brake booster and master cylinder from a 96 xj. Brakes work great. New calipers up front last month.
Odometer reads 108xxxk, please add 71k to that (Previous owner swapped out the gauges to get a tach).
Front and rear axles were rebuilt with new bearings and u-joints spring 2005.
Rear has an Auburn LSD.
Front is D30 high pinion, rear is 27 spline 8.25.
Windows were tinted, not the greatest job but acceptable.
Aux tranny cooler up front.
130/90 H4 headlight conversion with wiring harness. (YOU WILL BLIND PEOPLE)
Auxiliary lights front and rear.
Weather resistant CB radio.
Separate Wiring harness installed for all accessories, fused and relayed.
4.0L Engine has run Synthetic since previous owner bought it and it runs LIKE NEW! Very Smooth.
Newer battery.
Rear tow hitch.
Front tow points.
Drive shafts both front and rear fully rebuilt.
New plugs, wires and coil.
New custom rock rails
Pretty much everything on the truck is either new or recently replaced.
Now the bad part...
The transfer case leaks at the back where the drive shaft hooks up. It doesn't leak fast, but it does leak and it spins onto the cat, so it smells.
Front swaybar is off the jeep. I have it, along with quick disco's. You would need to weld a tab onto the axle to hook them up. I've been using it as a daily driver and hasn't been a problem so I haven't worried about the swaybar.
Looking for 5500 and can help deliver up to a reasonable distance. Also open to trades.
how much for the girl in the jeep?
Ill give you a 2005 Kawasaki 750 for it. Worth about the same.
05 Kawasaki z750s 60xx miles. Custom paint. Needs a rear tire. 60+ MPG.
PM me and let me know.
always a Toyota lover at heart
interested in a 1998 std cab tacoma? 4x4 auto-tranny 4cyl
dual ARB air lockers,5:29 gears, exterior "rhino-lined"
LCE exhaust header, Magnaflow CAT and SS CAT BACK exhaust system, LCE valve cover,K&N FIFPK, manual hubs,twin stick available. many spare parts.
THIS truck is not street legal, but can be again, with tail lghts.
BENT-UP rear bumper, recently powder-coated,custom front bumper and stock available,UWS toolbox,fr/rr diff breather ext,MOBILE 1 motor oil, gear lube, ATF in tranny and P/S system,MAGNEFINE inline filter and P/S system
Discussion Starter · #13 ·
Please post up some pics.
1 - 14 of 14 Posts
