Hey Guys yall have been very helpful with me on my 98 tacoma and now I need to see if I can get some help on my parents 94 toyota 4x4 v6 x-cab.
Here is the problem:
If you jack the back end up off the ground, should you be able to put it in 4wd and pull it off (the front tires pull it on off)? That's the first question my dad has (he isn't great with computers and I'm helping him out).
Basically they kinda got stuck yesterday and he doesn't believe it was working.
Thanks in advace!
Yes the hubs were locked in. What could be wrong?
Ok, dad jacked the truck up where all 4 tires are off the ground and he said the cv joints are turning but the tires are not turning.
If the cv's are turning and the hubs are locked then the only reason the 4x4 would not work (tires no spin) would be in the hubs.........as in BOTH would have to be non-functional which could be the case but It is unlikely that both have gone bad completly.......I would make double sure the hubs are FULLY engaged.
