1 - 3 of 3 Posts
Hey guys, I just purchased a 95 t100 and am having some issues with it. It will crank and idle with no issues. When i rev the motor both driving and while in park it will bounce between 2200 and 3000 rpms like it has a miss or is hitting a rev limiter. Any advice on what to check or possible solutions? Will try to attach a video of what it is doing. No check engine light. Thanks!
Have you done a tune up on it?
Change your plugs and wires. Could be a fuel filter that needs replacing too if it's partially clogged.
Quick RPM changes like that rely on good air/fuel ratio feedback. Sounds like you might have an issue with your MAF or fuel delivery. Start with the easy stuff like cleaning the MAF and intake. Then move on to the fuel filter and then plugs and wires.
1 - 3 of 3 Posts
