I have a 96 Tacoma 4x4 2.7 standard cab my problem is my right
turn signal when I turn it on both sides sart flashing and when I hit the
brakes the right front light comes on.
I'd say you have a problem with your turn signal switch. It could be ashort in the wiring somewhere though. Try a junk yard for a turn signal switch. They are $$$ at the dealer.
you might, want to start by replacing a few bulbs. i have seen in some isolated cases when a bad bulb shorts out and causes others to act funny. also check grounds underneith the truck.
First problem. sounds like you have a short in the steering column. Thats where both left and right intersect?
Second: Does the brake lights also come on? Brake lights and turn signals use the same lights. You may need to find where the two interconnect and look around there?
it wouldn't be a bulb they are on a parrallel?.. try what gsmnuffy said..
Did you recently install aftermarket taillights?
