Hopefully someone here can set me straight on the rack and pinion on my 96 taco (11-95) prod date.
Half the time I read 95-96 only the other half I read 95-03 is all the same.
This truck was put in the ditch and then I obtained it. I got the body all back together but the rack is bent.
I had to replace my rack a while ago (95.5 taco) and i got one from a 99 and installed it with no problems, but when i was looking for a rack (used) they kept telling me that racks were year specific and the newer ones would't work, nobody could tell me why. The rack i found i got for cheep so i decided to try it and it worked fine for me.
If i were you i would take the old rack with you when you find one and if the new one looks the same i would try it on the truck and see what happens.
I hope this helps you out a little and may be some one here can tell us what the difference is in racks between years.
i got mine from a 98 4 runner. worked but has different outter tie rods.
