1 - 11 of 11 Posts
My '97 2.7L started mis-firing like mad today...so bad that I can smell gas...strong gas odor in the exhaust. Not throwing a code. New plugs. Original everything else as far as the ignition goes. What's the most likely suspect part?
Plugs are properly gapped, etc? Does your truck have wires or the coils over the plugs? If the plugs are good, I'm thinking you might have damaged one of the wires (if you have wires).
Can you narrow down the misfire to one cylinder or is it multiple cylinders? You should have a CEL if this is happening...
Discussion Starter · #7 ·
No CEL. I have wires. The misfire problems showed early warning signs right after I changed the plugs and front O2 sensor 4000 miles ago. Now it's really bad. Like you said, maybe I damaged one of the wires. They are 10 years old...
Modern coils are SUPPOSED to last the life of the vehicle right?
Double check your plug wire ordering, that could cause harsh misfire.
1 - 11 of 11 Posts
