1 - 20 of 30 Posts
After spending hundreds of hours on the forum and sending a ton of PM’s its my turn to try and help someone out. The truck is my DD 97 T100. With the 3” body lift Ball joint spacers and AAL in the rear on 35s I was destroying CV shafts like crazy and bent 2 idler arms.
After breaking or bending something on every trip I decided it was time to start gathering parts. A huge thanks goes out to Zac at Rustys Off Road and also Josh at Inchworm Gear. Once you deal with companies like those its hard to call anywhere else.
Parts List: Front
Chevy D44 passanger side drop axle
Re-geared to match the rear 4.56 with aussie locker, warn hubs
Skys Off Road Full size axle front hanger
Rustys Off Road RX300 shocks
Trail Gear 47” long 3” lift front leaf springs, shock hoops, 5” shackle, shackle mount (from josh @ inchworm gear)
Independent 4x Right side flat top knuckle
This is how the front sat the night the swap started. (cell pic sorry)
Discussion Starter #2
Since both Cv’s were blown, the idler arm was bent, and the control arm bushings were frozen allowing for no caster adjustment I took out the plasma cutter and went to town.
The front diff with 4.56 gears and aussie locker is still available for sale. It works great and has never given me a problem.
After an hour fri night I had the front cut off and was ready to start grinding.
Saturday a few buddies of mine stopped over to help out. Since the plasma cutter is 20 years old and I never used it before, I left a lot of over hang from what was cut off.
The upper control arm mounts are also a part of the motor mount. I did not want to leave them open so I cut them as flush as I could with a sawzall and made some caps from some 3/16” scrap.
I never really saw any rear shackle mounts/setups so I decided to try my own way. I used a piece of 3/16” plate steel about 9” long 5” wide to make the base for the rear shackle mount. The rear mount is a Trail-Gear (from inchworm gear) shackle mount and the gussets were from rustys off road.
mass huh? part of any clubs down that way? Im up in northern vt but wheel all over.
i just joined northeast toyota crawlers, i also have a small group of 12 that wheel with us every other week during the summer. i can Pm you a schedule as soon as we line the dates up.
I pushed the front hanger as far forward as I could and after double checking everything was straight tacked everything in place.
I couldn’t wait any longer and wanted to see a little flex. Set the truck on its own weight and went up with one lift arm under the axle. I stopped before it got to close to the lift incase it slid off.
I used the pre-made 14” travel shock hoops from Inch worm Gear and Rustys Off Road Rx 300 remote reservoir shocks in the front.
After a whole weekend of nonstop work the front end was done and ready for paint. Imho the truck is way too tall for 35s. my plan is to remove the body lift and let the front settle before doing any suspension changes. It rides down the road awesome and has way less body roll then the ifs did. It handles the normal bumps a lot better as well. I did have a problem on my first road trip. The front leaf springs had a lot of play in the hanger and caused a serious death wobble. I made some small spacers a little wider then a washer for each side of the leaf spring bushings. This took up 98% of the play and stopped the death wobble. I am still waiting on a front drive shaft but took some poser shots in my back yard.
How come you didn't add any reinforcement plates to the frame? Nice work non the less
The T100s, non tacoma trucks, and older 4runners actually had a real frame compared to the tin can the tacomas have for a frame. There is no need for frame plates.
Discussion Starter #10
thanks.
i had ordered the set from trail gear but they did not line up very well. i am going to make my own soon. once i finish my rear bumper.
I ordered my front driveshaft from Tom Woods, he asked a few questions and shipped it out quick. I swear he started building it when we were talking on the phone, and finished it before we hung up.
Still can't go wrong with plating it, beef :cool:
I Sas's mine in 2007, still need to frame plate mine, and add under engine cross-member .
Discussion Starter #13
Thats where i called for mine. i used the print out sheet they had on-line for the measurements.
Did you do any changes to the axel for caster and camber or pinion angle?
Thanks! Truck looks great.
Discussion Starter #17
thanks. i have not done much to the truck since i swapped it because racing started. i did use 6* shims but i think the caster is still wrong.
i ordered 4" shackles from inchworm to drop the height and they should be in monday. from there i will work on the caster and see if i have to turn the knuckles. the camber is also off, the tires lean \-----/ pretty bad. i read about off set ball joints and may try those.
I'm about to have to start thinking about this too, I'm running 5" shackles right now and my pinion is almost flat with the trucks weight on it. I was thinging 6* shimswould prob get it just about right.
Discussion Starter #19
mine was pretty flat as well. i will take some before and after pics with the 5" shackles and 6* shims then the 4" with 6* shims. my caster is well past 6* towards the back of the truck so hoping the smaller shackle will fix that
Cool, I wanna get it set right before I start messing with the drive shafts. I'm running TG 5" springs front/rear and I'm thinking I will be removing some leaves to drop it some, I'm sure they will settle some.
1 - 20 of 30 Posts
