1 - 2 of 2 Posts
I have a 1997 Toyota Tacoma 2.4L automatic that stalled on me at a stop sign (3 miles from home; so it was just getting up to regular operating temp). After that, it would start, rev up then stall out. Sometimes it stays running, sometimes it stalls after start-up.
Originally OBDII Code was P0300 (Random Misfire), then later got a P1300 (ignition coil #1).
I have do a LOT of work to fix this issue, and still have not been able to cure the issue. It is better, at least now the stalling is unpredictable, instead of ALL the time.
First, everything that I replaced since the start of the issue:
1) All Spark plugs
2) All Spark Plug wires
3) Distributor Cap and rotor
4) Fuel Filter
5) Fuel Pump
6) Fuel Pressure Regulator
7) Ignition Coil
Cleaned:
1) IAC
2) Throttle Body
3) MAF Sensor
Added a can of SeaFoam to the gas tank and a little to the crankcase as well.
Since all of this work, I have been able to get it started and keep an idle, drive it a short distance, then it will stall out and not idle afterwards. Then the next day, without doing anything to it, it will start and run again. Now, Sometimes it Stalls, sometimes it doesn't. I have been working on this issue for nearly 3 weeks now, with no certain fix.
THANK YOU SOOOO MUCH FOR ANY HELP YOU CAN PROVIDE !!!
1 - 2 of 2 Posts
