You need the complete engine and full harness, ECU and probably new dash cluster.
Hi. Thanks for your input, just got the ECU for the engine. All I need is the harness. I’m a newbie here lol. Is there a link to this swap? Much help. Thanks
There is no write-up for the swap. You are doing custom work with steps that are specific to various models. Assuming the ECU is for the 98 model year, you need a harness that matches the ECU. I think 98-00 models will work, but don't quote me on that. You need the harness that also matches with your engine and transmission combo.
The dash cluster will be interesting if your 96 model has a speedo cable. The 98 harness and dash cluster is electronic speedo, so you'll have to convert the speed sensor.
Be sure to check first on the harness. I have a 98 2.7. The first harness I bought was supposed to be for a 98 but was for a distributor. Apparently, there was a mid-year change in 98 to 2 coils.
