1 - 8 of 8 Posts
I have a '03 prerunner. Just added 134 to the a/c, the a/c clutch cycled normal (cycled at about 1 minute or so). Now it cycles like every 15-20 seconds and doesn't blow as cold as it should. It's not over charged, guage shows in the safe zone. Is there a relay or pressure switch that could be causing the quick cycling? Truck has 60,000 miles. Any help would be greatly appreciated.
It wasn't blowing very cold air so I added 2 cans. If I added too much wouldn't it show to much pressure?
Yeah, unless the crap pressure guage that came with the cans isn't working correctly. Get a second pressure check and compare. Or you could hook the pressure guage up to another car that you know is charged correctly.
thanks guys, Showstop had it right, over charged, I remove some of the 134, brought down the pressure a bit and it works good. Thanks for all of the input!!! :clap:
1 - 8 of 8 Posts
