1 - 11 of 11 Posts
beat taco said:
all parts are brand new, I have reciepts and discounted everything!!
$1600 takes it all. located in portland oregon
1. precision gear 4.88's for a low pinion d44 & master install kit $175
2.rd116 arb arir locker, low pinion 30 spline, with timken bearings $550
3.sky high steer, complete with flat pitman arm and 1 ton chevy tre's, studs, cones & washers $475
4.high angle driveline pinion adapter $80
5.pro comp front brake lines $60
6.'90 toy 4x4 steering box $75
7.chevy flat top knuckles with moog ball joints pressed in (the ball joints were $177) $200
8.warn premium hubs and all seals/bearings from the spindles out & doorman studs $90
9.all t-100 2wd oil pan parts $100
I'll take the 4.88s/master install and the pinion adapter (assuming it's D44 to Toyota). The low pinion means non HP right? There isn't some mystical D44 type that I'm missing right?
I'll also take the t-100 2wd oil pan parts if they're for a 2.7L.
Please send pics to [email protected]
Thanks.
~Miguel
Would you be willing to separate the Sky kit? I'm also interested in the tie rod and drag link (if they're the right length) as well as the TREs. Can you get me the legths for the TR and DL? Thanks!
~Miguel
beat taco said:
could take a while to get pics, they are new in the box, sorry, but i dont want to break up the sky kit, i'm pretty sure your stock oil pan is fine. mine is for 3.4
No big deal on the Sky kit. Can you quote me on shipping for the other items I mentioned before (gears and pinion adapter) to 94518?
Thanks.
FYI, even us 2.7L guys need to convert to t-100 2wd oil pans but we need the 2wd 2.7 t-100 one.
~Miguel
1 - 11 of 11 Posts
