1 - 3 of 3 Posts
Yes. I'm pretty sure its close to 11qts for a complete fill. How do you plan on flushing the trans?
Drain the fluid through the return line at the radiator into a measured container 1 or 2 qts at a time. Then refill the same amount until I go through 12 qts of T-IV. This is after I do a pan drop and filter change.
1 - 3 of 3 Posts
