Well, it appears I've spent $700 on a suspension that is for crap on my truck.
DC 4X4, ARB, Winch. Downey Coil Overs. After putting everything on, the front seemed a bit less responsive than I thought it should be. Not bad, but coupled with some stiff rear shocks, the ride felt odd.
Took out cable, weighed at 30 lbs with fairlead, and thought I'd run without it for a few days to see how it went.
Went okay. Felt better. And I was on the verge of just ordering synthetic line and aluminum fairlead. Tonight though, I went across a dip in the road. Bang on the left front. WTF. Went back. Slower, but same thing, not as loud. CRAP. Coil slap.
I've got it set to 1.5" of lift. I'm a little peturbed that with even moderate lift I'm getting coil slap. Seems to me like this is a design flaw, period. I've got the collar cranked up about 2" from the bottom, so about half way through the full adjustment. At this setting, I don't see how Downey would release something that would go metal to metal before it hit the snubber or bump stop. I mean, come on.........I don't care how well the springs are handling the weight, sooner or later everyone is going to "bottom out" and when that happens, it should NOT BE metal to metal on a non-modified suspension kit, correct?!
What about the guy with the pre-runner with little weight up front, and his collar cranked all the way up for 3" of lift? The first real good dip or ditch he hits and bottoms out, he will be going metal to metal with coil slap as well. That is not acceptable to me.
Do I have grounds to be ticked off here? Or am I going to have to add height to the bump stops or get different coils so I don't go metal to metal every time I hit a freakin dip in the road?
At a minimum, I'm out $180 to put Tundra coils on now it seems, and live with the too stiff ride and reduced flex that set up will bring.
Not pleased.
Not pleased.
