Okay, I have some additional info that might help me or someone else down the road. I mentioned above that on occasion I have been able to drive 20-30 minutes and not had the light come on. So I got to really thinking about that this morning, why, what's different?? A/C, that's been on the last two months. HEADLIGHTS, what if I turn headlights on does that make a difference.
So I tried it, I left the house, headlight switch on, middle of the day, drove 18 minutes, NO ABS light. Stopped, ran errand, then went to next errand, drove 15 minutes, NO ABS light. Stopped, ran next errand, then on to next location, 7 minutes, NO ABS light, then on to the house, for final leg of 6 minutes, and NO ABS light there either.
I'm onto something here I believe, but why, what the hell difference does ABS care if headlight switch is on or not????? Normal configuration, starting truck and put in gear or rolling forward, headlights turn on by themselves, although I don't think they are as bright as if you turn the headlight switch on itself. Other differences, tail/marker lights, they are not on normally but they do come on when you turn headlight switch on.
I'm still confused as to why this would make a difference, a voltage bleed through, a high resistance at a headlamp socket or relay, IDK, but something is tied in here between the headlight circuit/stoplight circuit and ABS giving a flying F%&@.
I need to look at more diagrams and more testing, but if anyone has thoughts on it, I'm all ears.
