I have another 98 Tacoma with ABS and was wondering if anyone had converted one to manual brakes, my 99 is very similar and it looks like I would have to reroute a few brake lines and purchase another non ABS master cylinder. My reason behind this is that the ABS pump is bad, causing a hard pedal, and the repair parts are a little over priced. I would leave rear mechanical ABS the same, simply do away with other ABS equipment, as far as the light is concerned, I would simply remove the bulb. Keep in mind that this is a utility truck used for work, and sees alot of offroading.
