1 - 9 of 9 Posts
I am planning on swapping my front calipers (1985 4Runner) out for the V6 calipers, and FJ vented rotors. Since it is also recommended that I replace the MC at the same time, I am looking at a few options. I found a 1993 pick-up with the calipers, and master cylinder, but the guy says that the truck had ABS. I know that the preferred is the 1.0" non-ABS MC, but will the larger ABS MC work as well?
Also, how is $40 for a pair of used calipers, and $45 for the MC/booster?
great price on the used parts, but make sure you check the pads. II dont know the difference on the abs/ non abs mc so i cant help you there.
Thanks, I was planning on checking the pads, and most likely replacing those at the same time. I have a "guy" who works at an auto parts store, and can get me his friends and family price on the rotors and pads. I guess he could do the calipers and MC too, but I doubt he could beat that price.
- there's no difference in the MC between ABS and non-ABS
- if it has a 4 bolt mount, it'll bolt onto any other Toyota with a 4 bolt mount (Supra, Celica, truck, 4runner, etc)
- most 'Yota MC's have the bore size cast onto the side of the MC, go with 1", larger is not better
I knew you'd chime in!
So, I am looking for the 4 bolt to match up with my 4Runner. I will check back with the seller and find out it it is 1" or 1 1/4". So thanks!
Here's a bit more for ya on MC size
86.5 - 89 Supra = 1" bore, 4 hole mount
82- 86.5 CelicaSupra = 15/16" bore, 4 hole mount
86 - 89 4runner = 13/16" bore, 4 hole mount
90-95 4runner = 1" bore, 4 hole mount
96 - ? 4runner = 1" bore, 2 hole mount - won't work
~91 - 95 MR2 = 7/8" bore, 4 hole mount
Discussion Starter · #7 ·
Thanks. I ended up with calipers, MC and booster from a 93 PU w/o ABS. I believe got the right one, based on some info i found on Pirate. Sound right?
Sounds about right - do you know if was a V6 or not? I'm not sure if V6 mattered as late as '93, but early on it did - as long as the calipers have S13WB you should be golden
Discussion Starter · #9 ·
Yeah, V6. I'll have to scrape all of the built up brake dust and grime to check the part number, but I think it's right!
1 - 9 of 9 Posts
