1 - 18 of 18 Posts
can anybody give me an answer to this equation....(881x2)+DC=x inches of lift.
Discussion Starter #2
never mind on the nat board it says the answer is 1.5"
do you think i'll be able to clear 32s (on a trail)?
technically you can clear 32's stock..... so yeah i think you should be able to
What width?
IMHO, 32x11.50 is a ridiculous tire size. Hardly any ground clearance improvement, and increased fitment issues. I would recommend 33x10.50 (or metric equivalent)... Get the ground clearance and avoid the fitment issues.
i'd like to do the 33s but right now i don't really have the money for a bl to add to a 3" susp lift. i know i could save pennies but i'm tired of looking at a bone stock taco for the last 2 years. i'll crunch my budget some more but i don't think i can afford much.
That's the great thing about staying narrower - if you can fit a 32x11.50, you can PROBABLY fit a 33x10.50, and you don't have to buy new rims - very cost effective way to get more ground clearance!
Discussion Starter #9
i wanted to go a little wider than the 10.5 i have now. if i could find 33x11.5 in a 15" wheel i'd probably do it. i really want 33x12.5 but i can't afford it. but i'm willing to settle for 32s. i'll probably wind up getting 882 system from toytec and buying the bl for 33s when the 32s go bald.
Discussion Starter #11
i dont have 16s (on my f250 i do) on the tacoma.
I initially had 881s on my dcab, swapped for 882s within a few months because the front is lower than with 882s. Haven't looked back after putting on the 882s.
If you do the 881s and want a bit more lift without sacrificing the "softer" ride, talk to Doug or Chris at Toytech about adding a spacer.
The wheeler's offroad 15" wheels fit almost all the late model tacomas, except for a few equipped with VSC (this according to their website). So it's possible to use either metric or standard tire sizes on just about any Tacoma, although I really don't see a consistent price advantage either way.
Midnight Rider, I have a set of 1/2" front spacers that I was running atop my 882s, but it made the front of the truck higher than the rear, so I removed them. Doug sells 'em for $60 a set (TOP1-T, http://www.toyteclifts.com/spacersoffroad.htm ). Make me an offer...you'll neet to get longer studs for your top plate as well, (I lost mine) I'm sure Doug will charge a nominal fee for these. PM me if this sounds appealing. 3/4" of lift relatively cheaply and easily may help you fit the tires you like.
Discussion Starter #15
i recently bought 15" steelies and i don't plan on buying 16" wheels (would wind up spending more money). i think i'm just gonna go with 882 kit from toytec (when ever i sell my 75 cougar)
Re:....(881x2)+DC=x inches of lift.
(881x2)+DC=?
(882x2)+DC=4.0
I just put OME 882's on my DC and got close to 4 inches on lift in the front. Even with the ARB and the winch weight thats what it came out too. It's only been on a couple of weeks and hasn't cmopletely settled but thats what I got....... :)
you got 4" from 882s? That's gotta be a very steep CV angle, huh? I imagine they'll settle just a bit, too, although I haven't seen mine settle in a couple thousand miles of hard driving/offroading.
its about 2.5 over stock..... but trd progressive rate coils are notorious for sagging. so over what he had before he probably got 4 inches....
1 - 18 of 18 Posts
