1 - 20 of 24 Posts
i need a set of hubs for the front of my 99 taco... doing the 4x4 conversion... are the 4x4 rotors different from the prerunner ones ?
rotors should be the same
Wow, yep better start that searching. I've been doing it for months. I've got the info down now, but sometimes a detail still stumps me so I hit the search page.
Link's bad ;)
The requested URL /FSM/Repair...h4wdpr/comp.pdf was not found on this server.
You copied it truncated....hehe
drabnor said:
if you guys need any help let me know, ive done the conversion to my rig
Well I've got one question that I haven't really found an answer to yet, and it pertains to this topic:
Can the necessary parts for manual hubs (or ADD) be pressed into prerunner spindles, or are they machined differently?
it can be, but why? 4wd spindles are cheap
onekickkawi said:
ok hows this work
hows what work? you want to buy what i circled
Discussion Starter #14
ok i have everything in blue.... I need the HUB..... its in red
what you circled was the the spindle and hub assembled..
check out what i circled
ah, good luck with that, i doubt anybody will have just that part
try toyota :dunno:
Discussion Starter #16
there $155.....each What other trucks have that part... tacoma and 4runner... im gonna check out pick and pull
did you check with trdparts4u.com ? they have the best prices on oem toy parts
Discussion Starter #18
looking right now.. just called a few junkyards up. dont really wanna buy new for a hub.
you should be able to get the entire assembly for the price of a new hub and the install labor will be minutes rather than hrs with no need for a machineshop press ;)
1 - 20 of 24 Posts
