1 - 11 of 11 Posts
i searched dident find anything. anyway i kinda sunk my truck the other day airbox was full of water. no engine problems thank god. but the only problem is the airbag light is on now. i tried to turn on and off the pasanger side airbag. nothing happend. i disconected the battery. nothing.. im thinking the sensor is just wet still. i looked at the fsm. and they way the sensor is located it had to be wet because it is mounted below the air box... any one run into this before?
Had a similar experience with the AirBag light, without the water though. Check the connections behind the dash where the airbag light/switch is located. I found that one of my connections was loose and just needed to be tightened up.
I have had this issue as well, and also with no water. Mine is still on to this day and it happened when I got my stereo installed. I have had it fixed since and it just keeps on coming back. I have heard about a very sensitive switch behind the dash so check that out. let me know if you find anything that would be a simple fix.
Iggy said:
where behind the dash are they?
Behind the dash where the AirBag switch is located- the one you can put your key in to turn the passenger airbag off/on, just to the side of the A/C vents. Assuming you don't have a newer Tacoma.
Iggy said:
ok i disconected the front sensor and reconected it the sensor by airbox nothing
Try the other side too (there's one on each side). On my 2001 Taco there is a main airbag computer right behind the extra cig lighter outlets (center of lower dash).
Maybe a OBDII code reader will show the trouble code?
1 - 11 of 11 Posts
