One quick (relatively) easy thing to check is the seat belt plug inder the drivers seat.
Unfortunately, you will probably have to pull the seat out to get to it, as its UNDER the carpet.
The seat is actually pretty easy to take out...takes about 10 mins, with a 14mm (and possibly also a 12mm< I cant remember for sure)...
Once the seat is out, you can follow the wire from the seat belt, along the trans hump, to a hole in the carpet. A few inches inside the hole is where the plug is mounted.
Mine somehow had worked loose, and the plug had come apart...I'm guessing maybe from jamming stuff in and out from under the seat?....My light went out once I plugged it back together....
I dont remember whether there was another plug on the passenger side also or not ....
