Ok I see where you are coming from and I agree with you to a certain extent, however I don’t fully agree with this statement,
Poopshute said:
Keep in mind that SC setups are forcing air into the engine meaning that air restrictions won't pose as much of a problem.
The point of a supercharger is to introduce more air to the engine. Having less restrictions in the intake path is the key factor of the amount of added air you are capable of introducing. Just like with the exhaust. If you have a restriction in the back end the supercharger can’t do it’s job to the fullest extent of its abilities. Don’t forget SC are rated by their ability to force are, or air flow rate in Cubic Feet per Minute or CFM. No matter how high the CFM of the supercharger, if the intake is as small as a straw (with very low CFM) it will not do much in the form of forcing air into the system. With a non aspired engine, there is much less air that passes through the system (intake, engine, and exhaust). This is why I said it will be more beneficial for a SCed engine.
Now what you said is true that the stock tube has a resonator, and yes, most people believe it restricts air. I have yet to see dyno numbers or actually measured CFM numbers to validate this theory, but I have heard of people having to modify their fuel maps because it tends to make them run lean. Which means it is doing what it is suppose to and allowing more air to flow through. You mentioned you felt more kick after you did the deckplate and the Airaid. That may be so, but in most cases the “I feel more power” is psychological. How much of a gain is, “more kick in the 2.5k+rpm range,” and how much of that is psychological due to the added sound effects of removing the silencer/resonator? How can we distinguish between the added HP from deckplate mod and Airaid elbow? You may very well have added HP, but without a before and after dyno test a gut feeling is all we have to go with. My advice to the original person that posted the question was that in my opinion it wasn’t worth the money for a NA. I would rather do the resonator removal mod in that situation for the cost of a few buck vs 90 for the Airaid. If all you care about is performance, that is the way I would go.
Personally I like a clean set up and since I have already dished out all the money for the SC and other performance goodies I am planning on getting an Airaid elbow or fabricating something up to allow more flow into my SC. I still haven’t decided, but I do have a Supra MAF sensor I will be putting since it has a bigger diameter. However, If I get the Airaid elbow it is only to clean up the engine compartment more since I have already removed the resonator thus reduced the restriction.
