1 - 20 of 22 Posts
Deal Master
So I had a brainfart while removing the cone washers during my Front 4.30 ARB locker install.
In previous post, I recommended threading a nut (or double nut) flush to the end of the stud when striking with a brass drift to remove cone washers. I failed to listen to my own advice and managed to damage 3 hub studs.
Since the threads were damaged, rather than rethreading the studs, I opted for new replacements. Toyota part # 90080-11282
The manual hub studs are actually threaded on each end - So you must turn the stud counterclockwise for removal-
THis can be accomplished using double nuts, vise grips or a bolt extraction device. Double nut methods is the least destructive method, but not applicable in my situation since the damaged studs did not permit threading of a nut.
I purchased a bolt extraction set from sears a while back.
Sears # 952160/952161
I used the #2 Bolt-Out™ remover fits Hex sizes 5/16 in. and 8mm
which worked like a charm.
I installed the new replacement stud using the double nut method.
More pics here:
http://www.tacomaterritory.com/~grillmasterp/Aisin_hub_stud_repair/
GrillmasterP
Why the fuck are you hitting the studs to get the cones off?
Becuase thats how you loosen them up. Hitting them with a brass drift shouldnt damage them at all, but should allow you to loosen the cone enough to take it off.
I never hit the studs, always around them, never on them. Never any problems... whatever works, I was always scared I'd waller out the holes or bend the studs so I just find something solid and get a little "frequency" bouncing around them :) (oh, and waffle face hammers are hard on Al, duh)
Deal Master
Discussion Starter #5 (Edited)
Perhaps you should learn to RTFM :flipoff1:
Back to the subject-
When threading a nut flush to the end of the stud- I've never had a problem before. I have also hitthe chromed hub body before, but found striking the studs more effective (Quicker).
My problem was haste- and possibly using too heavy of a hammer in conjunction with the brass drift. I also skipped threading a nut onto the stud before striking.
No big deal- the hub studs are cheap.
Deal Master
Oh- yet another reason to strike the studs with a brass drift- or use a brass drift on the chromed hub body instead of hitting it directly with a hammer-
Although any damage to the hub body will probably just be cosmetic.
The hub studs are cheaper than the hub body too.
FYI - The hub bodies are chromed steel, not Al - Just the dial assembly is Al.
NorCal Chapter Pres
I always put a nut on the stud, then hit the nut and the stud together as one...
WD-40 and a very sharp chisle working my way around the back of the hub. I can have all 6 cone washers out in less than 1 minute. As long as you are careful, you will not damage the hub.
using anti-seeze solves all the problem of getting those washers out :)
Wgasa84 said:
So does breaking parts so they never have the time to get 'seezed' in there. :lamo:
Yeah yeah. I seem to be following after Dan anymore.
at least you are learning from the master, LOL
Deal Master
Discussion Starter #12
This is actually the first time these particular hubs needed to be removed. (Hence no anti-sieze)
The cone washers were indexed and copper anti-sieze was used during re-installation
I use anti-sieze on almost nearly every bolt I touch, with the exception of ring gear & lca bolts - (use loctite)
When I started all that crap with my axle stuff I didn't even know there was a FM :D Good tip though- although most of my stuff now is like Wgasa's, never has time to sieze its on and off so much. And all assembled with antisieze originally.
you people and your hammers. dose anyone else use the small flat screwdriver anymore? just tap it between the split in the cone.
NorCal Chapter Pres
X2. I put anti sieze on the ones you sold me. Didn't look like they had any.
Banned
More pics here:
GrillmasterP
Why don`t you buy the Front Range hub stud upgrade?-you shouldn`t have to ever replace them again....their ARP studs.
pussy... :rolleyes: Hit that shit like a step child son :D
the stuff wears off when you swap CVs all the time :p I didn't have any with me the last time I had to pull one.
Deal Master
Discussion Starter #19
-I've already changed them- Bought them from Shannon @ Champion since I am in Houston. (I also have about a dozen spares now)
-Looks like they are about 4-5x the price of the OEM studs-
-Don't expect to make the same mistake again.
I also think they may be too long for the application-
Murderman Had spare front Axles/hubs from earlier model trucks-
the ones we pulled were too long
1 - 20 of 22 Posts
