1 - 17 of 17 Posts
Im located in San Diego and wanted to know of any shops that would align my 93 LT ??
i know any shop could possibly do it but if there are shops you would rec. that i go to please let me know. Ive asked ORW but they dont like doing LT alignments. I would try it at work but my rack may be just to narrow to fit the truck on.
-thanks
go buy some turn plates, tow plates, a camber gauge and 2 identical tape measures from Harbor Freight
Then you can do your truck, and make some money doing others
my local express tire in pacific beach said they would do LT kits if they mainained the cams for adjustment.
so as to not start a new thread, which i may do anyways, Has anyone had problems getting their CAMBURG kit with the alignment on the lower heims done???
I just paid for a lifetime alignment and am worried they wont be able to or wan to do it with this kit.
Mike
They aren't really heims, as in they don't thread to adjust alignmnet whatsoever. With the kits your alignment might be weird for a little while, but it can be aligned like stock
i guess i still dont understand????
so how is alignment accomplished:confused:
okay, i was confused about that part, actually dead wrong in how i thought the arms were:D
i though the stock alignmnet cams were not used with this kit but now it seems like it would have to...
so you neverneed to get it aligned...ever???
wow
You align off the lower arm using the stock eccentric cams which are built into your lower a-arm pivots, the camburg uniball pivots align the same way urethane bushings do, camber and caster are adjusted using these cams and toe is adjusted at your tie-rods, you absolutely need an alignment
gotcha, i pm'ed jerry z on rdc and he said no more cams...which confused the hell out of me. gotcha thank you all.
Mike
Mike
yup me too. the local firestone told me i can use my lifetime alignment on an LT but i have to pay an initial 60 bucks. Fckin gay. Sorry just had to add that.
60 bucks thats all?? stop crying.. I paid 200 for lifetime..
no i paid 175 for a lifetime, but if i change out my UCA and LCA (aka LT) i get charged 60 bucks for the first initial alignment, then the rest are free.
just do your own alignment i do my own alignments. its not that hard to do it
is that why those rugged trails were worn so bad on the side of the tread, just messing with ya man
ah makes sense now.. Still not bad if they do a good job.. That is the hard part, is doing a good job at it.
if it keeps the cams then I will not have to pay more and they willl do it no problema. plus if something is wrong i know the manager pretty well and he'll make things right.
Mike
1 - 17 of 17 Posts
