General question. In the past on carbureted cars I disconnected the battery when the car was running. If it died, I thought the alternator was bad
Now with computer controlled truck my manual advises NOT to do that. Anyone still do it on their computer controlled vehicles?
I've done it without issue. There is a risk, but unless your charging system is totally wacked, it shouldn't cause any damage.
You can do a simple charging test just by checking system voltages. You should see around 13.6-14.4 VDC if the alternator and charging system is working good. Load testing is different and you'll need a load tester or remove the alternator to be bench tested.
My battery charger has an alternator test feature requiring the engine to be running. I'm guessing that is a load tester(?)
Was just curious about my 2012 Taco. I was working on my friend's tractor and it got me thinking.
Tractor doesn't matter its diesel and no computer.
Your battery charger just has a function to check the output voltage. Load testing an alternator to make sure it can put out 60A-80A-120A or whatever its rated for is is a big heatsink type device that tells you how much load it can pull from the alternator.
If that is the case, I must be incorrect about my Dewalt charger.
