1 - 11 of 11 Posts
Last guy swapped intake and battery.. I think because of different radiator. Either way he used a cheesy intake tube that ripped way too easily. Do you guys have any ideas for a replacement tube? Thinking of getting something custom bent but I don't really want to spend too much $$
http://siliconeintakes.com/
Get the good stuff; I built the FMIC piping for my AllTrac from their parts. They're down here in the Springs so shipping should be pretty quick. You can get a discount by linking their site in your signature; send them an email with a URL and they'll give you a discount code. I think it's 10%, but a dollar is a dollar.
Between joiners, t-bolts and silicone bends, it should be able to come out pretty inexpensive.
Sweet thanks, thats exactly what I was looking for!! I'll check them out
autozone has some lastic stuff you can like clamp together. You could bend tube and throw silicone on the ends.
Did you get this sorted out? I found some leftover bits-n-pieces today; not sure if they'd fit the intake/AFM though... what size are they on your truck?
What I mean is: measure the throttle body and AFM and I'll see if what I have fits if you still need stuff. Also found some fancy T-bolt clamps.
Have not.. I will do some measuring tomorrow and let you know
Sorry for taking so long!
Measured and its 2-3/4" outer diameter on each. So 2-3/4" inner diameter of tube I need.
I also have ordered from the silicone intakes website and they have good prices and products. I used aluminum pipe and couplers for my'92 3.0L in my 4runner and will make a new inlet for my 3.4 swap as soon as it is finished.
Discussion Starter #9
So what pieces do you guys think I will need from silicone intakes to make it work? (2) 45* bends with straight pipe in middle?
Discussion Starter #10
Ordered a bunch of stuff so hopefully something will work out of the order then I can send the rest back!!
Discussion Starter #11
Got everything worked out. Thanks for suggesting silicone intakes down in the Springs!! I ended up ordering a 90* and 45* and a few other connectors to make sure I had something... Ended up using a 90* and a hump hose connector.
1 - 11 of 11 Posts
