The ez lift spacers go between the coil assembly top plate and the strut mount. It lowers the entire coil assembly without compressing the coils which is why is may ride better than the CF spacers. Remember, none of the spacer lifts really increase travel. So, the EZ kit has stock downtravel, but from a location 2.5" lower than stock which is why is can overextend the suspension. The CF spacers maintain an almost stock shock mounting location thereby keeping downtravel at a safe level. Yes there would then be less downtravel but it is safer. A set of limiting straps with the EZ lift would limit the downtravel to a safe place I guess. If is rides better, It would be a good option. But, then you have to get the straps and have them welded. Seems like a lot of work for a spacer lift. I ran the 2.5" CB spacers on TRD coils for 60k. It was firm, but I was very happy with it. I have never seen or used the toytec spacers, so I cant really comment on them.
