1 - 12 of 12 Posts
thinking of some basic pro comp 152's 16x7 with 4" BS. i know my 265/75/16's will fit, but dunno if i want to jump to 285's if that's too wide for a 7" wide wheel. too bad there aren't any used 255/85/16's in my area (socal) because those would be perfect.
It should be ok, people run 12.5" on 8" wheels without problems, so an 11.5" on a 7" should be fine. Why not get the same wheel in an 8" wide though?
Discussion Starter #8 (Edited)
1" means a lot more weight when using steel wheels. Plus they are more expensive. Found 16x7's with 4" BS that would work great with the 285/75/16's i want to run.
They are fine. I run 285/75/16 Duratracs on my 04 16" TRD wheels.
thanks for the reply, got the same wheels used panted black:D
Most of the wheels in this thread are 7" or 7.5" wide:
http://www.ttora.com/forum/showthread.php?t=152996
People have been running 285's on the 7" wheels for years without issues
sweet thanks
I ran 305s and 315s on stock wheels before the SAS I could air down as low as 10 psi no problems.
1 - 12 of 12 Posts
