I keep reading that some people get rubbing, some do not. Some need wheel spacers, so do not, etc. I won't be doing hard care wheeling, so an occasional off road rub would be tolerable. But on road rubs would not be.
I'm considering either Revos or the Nitto terra grapplers.
They rub with a lift unless you :saw:. And they will also rub on the uca so im gonna have to say no they will not fit.
From all the research I've done, they will only fit on stock wheels if you either use spacers or replace your upper control arms.
Some people are running them with a lift, but they're using spacers. Otherwise you'll need a wheel with more backspacing, but even then, I think you'll need a lift.
33's are gonna tear shit up unless you cut an inch or two off the front and back of the plastic flares on your truck.
