BadJammer said:
How difficult are these to install? can it be done in a driveway using normal tool (Sockets, air tools, floor jack..etc..?)
Some of these sites state 1 hour install time, is that acurate?
-Dennis Stiles
The coilovers will take you less than an hour. 3 bolts on the top plate, one bolt on the bottom mount, push down on the control arm, and the whole strut assy comes out. New adj coilover in, one bolt in bottom, three in top, torque, replace wheels. REAL easy.
With the Donohoes, there is an issue of the brake banjo fitting being real close to the coilover, and you have to lightly tap/bend it in a little bit. Like maybe 1/4" or so. It's in the instructions, not sure if the other brands had that issue or not.
--Scott
