Simple example
22RToy said:
Yeah, theory looks nice on paper, but doesn't reflect reality.
You could not have said it any better. I'm an engineer and I can tell you first hand that there can be a huge difference between theory and reality! On the other hand, sometimes you calculate something and it works out perfect. Who knows.
What about an example comparing two spings.
One progressive and the other not. Let's say they are both rated at 500 #/in, both about 14" long. How much of a difference will you feel on your Tacoma (assume V6, extended cab, 4x4, no aftermarket bumper or winch)?
Read comparisson between the OME 881 coils that are 14.4" (365 mm) long, rated at 500 #/in, not progressive vs Tundra TRD not sure about the length, rated at 475#/in (this figure is up for debate) but are progressive.
Assuming they are both of the same lenght, #/in rating the only difference being progressive or not, I would think that the progressive springs would give a much nicer ride.
I just found out that the OME 881 are the same length but different wire diameter than the Tundra TRD, see here
http://fastq.com/~sschaefer/front_coil-springs.html
Cheers :xbeer3: ,
P
