I had it as well. Mine was MAF signal out of range. It was from sitting withthe key "on" but not running for too long, then "off", then "on", etc... I had to power the FTC for mapping and left it on while monkeying around. If it doesn't run so many # of cycles in the correct range it will trip it. If you turn on and off repeating with out running the motor it will sometimes throw it. I don't remember how many trips it take before it erases it(20 or 50 cycles?). No worries. The flashing CEL is the one you don't want to see.boosted said:not blinking just on for a short drive and havent seen it since
wisctaco04 said:I had it as well. Mine was MAF signal out of range. It was from sitting withthe key "on" but not running for too long, then "off", then "on", etc... I had to power the FTC for mapping and left it on while monkeying around. If it doesn't run so many # of cycles in the correct range it will trip it. If you turn on and off repeating with out running the motor it will sometimes throw it. I don't remember how many trips it take before it erases it(20 or 50 cycles?). No worries. The flashing CEL is the one you don't want to see.
Scratch that idea thenGadget said:There are stand alone units that are supposed to be self tuning to some degree, but not a single one of them works as it should, none of them.
