As some of you know,
I'm getting ready to convert my 2002 Double Cab PreRunner from auto->manual and 2wd->4wd. (SafetyDang's conversion thread; I come in around page 3.)
For my conversion I plan on swapping my 2002 auto ECU for the 2002 manual ECU. As part of the research, I thought it would be a good idea to compile a list of the wiring differences between the two ECUs. Since I push data around for a living, I took the wiring info from the factory wiring diagrams and the ECU terminal chart and built a simple database to compile this into a table that shows the automatic and manual ECU wiring side by side.
I think it turned out pretty well, although since I haven't reached this part of my conversion yet I can't say with certainty how accurate it is, except that it's as accurate as the data I had available from the factory wiring manual. Anyway, at this point I have a template for doing this, and given the appropriate starting data, it isn't too hard to make similar tables for other auto->manual conversions.
To test this last part, I asked Yotaoffroad27 to send me the wiring diagrams for his 1999 3RZ PreRunner auto->manual conversion, which resulted in this table, similar to my original.
So at this point, I think my template is reasonably solid, and since I appreciate all of the help I've received so far on my own conversions I'd like to give a little back in the form of generating similar tables for other 'Early Tacoma' auto->manual conversions. I don't know if we can cover all of the Early Tacoma years and engines, and I don't want to make this offer so open-ended that I am doing this forever, but maybe I can knock a few of these out now before I start seriously wrenching on my own project in a few weeks.
What I need if you want me to do this for you:
Send me a PM with PDFs of the ECU wiring for both transmissions. The manual ECU wiring appears in the section labeled "Engine Control (engine model number)", and the automatic/ECT wiring appears in a different document labeled "ECT Wiring" (or similar).
I need both of these or I can't compile the data. I also need a PDF from the Diagnostics section of the manual that shows the ECU/ECM connectors, similar to the second document I linked to above.
Very important: These documents must be specific to your year Tacoma, or this exercise is worthless. Not all years are available for free on teh interwebs. If yours isn't available, spend $15 on a
http://techinfo.toyota.com day pass and download the appropriate diagrams.
Caveats:
1.
I am not responsible for any errors. I'll do my best, but ultimately it's on you. Use these tables at your own risk. That's one reason why the wiring colors are included -- always do at least a spot check of the wiring colors before plugging in the new ECU. If connector E6, Pin 1 is supposed to be Black, make sure it is before you plug in the new ECU.
2. I'm doing this for free, and I expect to post the resulting documents so everyone can use them.
3. I AM NOT AN EXPERT, AND I AM NOT GOING TO TROUBLESHOOT YOUR ECU WIRING!! I am compiling data for you to use based on the factory wiring manuals. That's it -- you get what you pay for.
4. I'm willing to put this offer out there for a few weeks, at least until all of my parts arrive and I start wrenching. I have a life, a family, and a job, so I will only work on this stuff as time permits. Now that I have a working template, I think it will take me ~60 minutes or less to hand enter the 65-90 ECU connections and generate a PDF.
5. At this time, I only want to do same year/engine auto vs. same year/engine manual, and I only want to do Early Tacomas (but am willing to do similar model 4Runners if asked).
Any takers?
-Jeff
UPDATE 7/6:
All done
Current version:
Early_Tacoma_ECUs_v2 is ready for download.
(Right Click, "Save File As...", etc. Total size is 2.7MB)
Feedback and corrections welcome. Enjoy!
Previous versions:
Early_Tacoma_ECUs_v1 is ready for download.
