So I inhereted a T100 fuel tank. Physical mount (on the right, opposite the main tank) looks pretty straightforward with re-routing of the exhaust & muffler. Here are my questions:
1. Can I set up a 'spill-over" fill from one tank to another, so that I don't have to use a seperate filler or do I need to utilize a booty fab door on either the bed wall or in the bed (I'd really rather not).
2. I'd like to set up an automatic feed from one tank to another, so that the aux tank is always used first, as a feeder for the main tank? I would think then that my guage would always be full until the aux tank ran dry and I started drawing down the main tank. The pump would have to shut off automatically in this case.
3. If that isn't feasable, how about a switch for one tank or the other? And how do I switch the gas guage? I understand resistance must match between both senders, but tht's about all I know. I had an old Ford that had dual tanks, and when you switched from one to another the gas guage automatically reflected the level of whatever tank you were using.... how can I accomplish this?
I am an electrical rock, but I can follow instructions... I appreciate any ideas.
