Normally, my auxillary power outlets shut off when the truck is turned off. Yesterday, I noticed that they just started staying on. Any ideas why and how to fix this?
That's crazy. Just curious, why would you want to fix it? I hated that my oulets had no power when the truck was off. Check your fuse box to see if the relay is seated properly- that's all I can think of.drinkintedbr said:Normally, my auxillary power outlets shut off when the truck is turned off. Yesterday, I noticed that they just started staying on. Any ideas why and how to fix this?
I know that one morning I am going to come out and my battery will be close to if not dead. I have a radar detector, and if a cop parks anywhere near where I am it will pick him up all night long.camaddy said:That's crazy. Just curious, why would you want to fix it? I hated that my oulets had no power when the truck was off. Check your fuse box to see if the relay is seated properly- that's all I can think of.
No, it just happened the other day. I went to get out of my truck and there was a cop in my parking lot. Got out and my V1 was going crazy still.drabnor said:did someobdy do the full time power outlet mod to your truck while you werent looking? lol
Check the relay that gets removed when you do the full-time power outlet mod listed in the "Cheap Tricks" section. Sometimes it gets gummed up.drinkintedbr said:Normally, my auxillary power outlets shut off when the truck is turned off. Yesterday, I noticed that they just started staying on. Any ideas why and how to fix this?
a radar detector would probably last for 6 months before killing a car battery.drinkintedbr said:I know that one morning I am going to come out and my battery will be close to if not dead. I have a radar detector, and if a cop parks anywhere near where I am it will pick him up all night long.
Take the batteries out of the radar detectordrinkintedbr said:I know that one morning I am going to come out and my battery will be close to if not dead. I have a radar detector, and if a cop parks anywhere near where I am it will pick him up all night long.
2 days on my roomates f150d33pt said:a radar detector would probably last for 6 months before killing a car battery.
there is no batteries. it plugs into the aux power outlets.BigDaddyToy said:Take the batteries out of the radar detector![]()
Right now, I'm not quite sure which one I used off of the top of my head. I have a Craftsman live wire tester (just hook it up to the door pin, then put the probe in each little slot). If I remember correctly, there are three or four empty slots, half of them powered 24/7, the rest only powered when the key is set to "Acc."cmw680 said:May I ask which one of the slots in your FUSE BOX in the cab you used...I have a 02 Taco and when I looked to see if there were blank slots I could use....all the empty slots were just plastic no metal showing to make a fuse work.
