BUMP to you because I would like to know also before I go buying it.jtaco1 said:How much lift does the long add-a-leaf from Summit give and do I need to run the BPV bracket with it.
about 2.5 is what i got out of itjtaco1 said:How much lift does the long add-a-leaf from Summit give and do I need to run the BPV bracket with it.
forgot about the bpv, just find a flat peice of metal and drill some holes. Raise it about 2 inchesjtaco1 said:How much lift does the long add-a-leaf from Summit give and do I need to run the BPV bracket with it.
