1 - 14 of 14 Posts
I'll agree with that!!! They are bright!
i got some from autozone for $20 they work nice and help a lot when you back up i attached a picture its not that great but its the only one i could fit in my attachment limit you can kind of see them the only thing to attach them was to drill some holes in the bumper and get some longer carriage bolts than the ones that came with them hope this helps
Miguel said:
I've got Autozone cheapies (~$20 for everything) and they work GREAT.
~Miguel
yes! not bad considering this is the 3rd set i've smashed on a rock :p
here are mine
They were like $12 each at Wal-Mart. "Round Tractor Lights"
Of course, the AJ bumper was a little more.... ;)
The place that mine are located (and the nature of All Pro's rear bumper) prevent that from happening. They are drilled directly to the bumper with self tapping screws and wired so that they turn on automatically in reverse or can be turned on manually with a switch.
Unfortunately it's not my lights I've been smashing on rocks... :rolleyes:
~Miguel
Can one just splice into the stock reverse light wire to power these extra backup lights? I know next-to-nothing about electrical stuff. Thanks in advance.
You really shouldn't. The stock wiring it not made to handle all the extra current for more lights if you are putting any decent wattage back there.
The way to do it is to run more wireing properly sized from the battery (fused of course) for the new lights and use the stock backup light power to run the coil of a relay that then controls power for new lights.
You can mount the relay in the tail light hole so you can get to the stock backup wiring easily. There is pleanty of room in there for the relay, just get one with a screw mount tab and use a sheet metal screw to mount it.
00Andy said:
I'm going to add supplemental backup lights to my truck since it's damn near impossible to see out the tinted back window in the middle of the night! Anybody have some good recommendations?
I'm thinking of either going with the AutoZone cheapies or one of these:
http://www.levineautoparts.com/trsibewolafl.html
http://www.levineautoparts.com/trpar46utla.html
http://www.levineautoparts.com/tr3hawoli.html
I'm trying to stay away from sealed beam.
those are all pretty big for backups unless you have a bed bar or something like this:
http://www.tacomaterritory.com/~ccorley/Misc Pics/bed bar/P1010225.JPG
Pilot makes a nice backup light that is around 1.5x3 with 55w bulbs. I found some at Auto Zone for just over $20 (might be the same as Miguel's)
they do tend to fill up with water though so I switched to a sealed beam type, round, as you see in the pic
a long HOWTO (with pictures and diagrams) on wiring up reverse lights, including how to set it up so they can be turned on automatically OR manually with a dash-mounted switch -->
http://www.ttora.com/forum/showthread.php?t=21166
jim aka the wrooster
Looks good Miguel, I need to do the same with my all-pro, but put dust lights in instead of clears. Did you weld light tabs on to hold them or what? Good writeup wrooster, keep them coming!
1 - 14 of 14 Posts
