My turn signal and brake lights quit working on my 97 Tacoma any suggestions
Sent from my iPhone using Tapatalk
First thing to check is if you have a trailer wiring harness installed. If so, remove that and check your lights again. Check the fuses in the distro block under the hood.
You need to locate your car's relay cluster to fix it, but if you're not that sure then you should ask for a mechanic's help.
