trail was awesome. actually harder in spots than most of Rubicon now. Several different lines to try and a few "bypasses" for some obstacles. about 5miles...took me 3hrs each way. There were 6 people there Sat/Sun and 5 rigs...all Yotas, including me...only 2 of us on 35s, others on 37s. Trail is actually narrower than Dusy is now...mirrors self-clearanced several times between trees
Some very tight multi-point turns to play with. Lots of diff grabbers right in the middle of the trail throughout and even with 35s I tagged front and rear multiple times...some near impossible to avoid. I would
not recommend this trail for IFS on 33s...much harder than Coyote Lk trail which last week was pretty torn up from Red Lk on.
The 3hrs is driving pretty much straight through...no spotting and just a few times backing up for better lines. Spent most of the trail in 4.7 1st and 2nd gear and used compound low a few times. Can be done (going in) with just a rear locker unless you try some of the insane lines
didn't need lockers going out.
Guy there said the next couple of weekends will be very busy as clubs are done with Jamboree and find out the thing is finally open.
Camping in 4 major areas...probably get 25+ rigs in there and 30+ people.
one FS shitter that is about full. Shit loads of fire wood but no fires allowed
fishing OK but not great. several lakes w/in less than a mile walk with more fishing.
Skeeters not bad if you use repellent...flies actually more of a problem.
When you get over the bridge the trail goes off to the right, off camber. very hard to see at the moment.
If you go on a weekend plan on getting in early!
