mount steering box as far forward as possible, take measurments for DL and TR decide on what ends you want to use and thats pretty much it. you can use 1 1/4 thick wall DOM sleaved with something for the TR, tap it and throw some 3/4" hiems in there, use a hard mount on one side. or you can just call parts mike like most people did, tell him which axle you are using and be done with it. i run the sky manufacturing flat pitman that i drilled out to accept 3/4" bolts so i could just run hiems there also. if you need some help i could drive up to huntsville and lend a hand when you start the swap
