Hi guys.My battery light is staying on.The battery is 2 months old I checked the voltage at alternator output 14.4 volts running 12.7 volts not running.I checked alt s fuse .Did voltage drop checks everything seems OK. I am missing something.
TIA Mike
Discussion Starter #2
Update
I did some research and found that the yellow wire on the 3 wire connector tells the battery light to go on or off. So I measured the voltage from that wire and it was .6 volts moving the wire around it jumped up to 13.6 volts and the battery light went out. So next step is to change that connector. By the way the way I was able to connect the meter to the yellow wire was I stuck a safety pin through the wire and connected a alligator clip to it. Hopes this helps someone in the future.
Happy Easter Mike
Update
Happy Easter Mike
Update
Happy Easter Mike
I had a similar thing go wrong with that same harness except on the fuse block side. The alternator hadn’t been charging for who knows how long and the low battery light wasn’t coming on. Left me stranded half way home between Moab and Austin.
One thing I’ve been worrying about recently is the age of the wire harness. As these trucks get 15-20, even 25 years old the elasticity of the electrical wire insulation is diminishing.
