ok so I went 4-wheeling the other day and the stupid battery light came one. so i checked to see if the battery was getting charged and it wasnt, so than I pulled the alt. and the brushes where stuck. I put it alll back together and now the battery is getting charged, but the battery light is still on? what would cause this? where should I start to trouble soot?
If you have a battery charger try that. You could of sucked all the juice out of the battery when it wasnt charging properly. Also check the water levels in the battery to make sure they are filled all the way. If you have to fill them use distilled water.
truck ~n~ tow
Did you reset the ECU ?
Pull the fuse or remove the battery cable to reset the codes
If that don't work... you got other problems...
Get yer codes read...
Mud is evil...
