trimmed side plannel level from the tail gate to the fender well made cut about 1/4" below tail gate. just took outer skin and left all the inner supports in the back corners. set a peice of channel over the bed rails to measure off of to get both sides the same. taped and marked cut and cut with a die grinder with a cut off wheel.
made mounts go to original bump mounting bolt holes
set the back at a 20 degree angle in and the sides at a 25 degree angle in.
Used 6" channel to help hide the body lift. when I get time I'm going to put a receiver hitch in to it. final cost will be about 100 dollars with reciever.
lol your truck looks a little small compared to the toys in the shop.... bumper looks good though. if you get a reciever hitch make sure that it has the double ring around the front lip and that you gusset it into the bumper.... then you can tow whatever ya want with it
That is an awsome looking bumber. Very clean. I'm a fan of clean. I just can't always achive it.lol
But the guy who posted above me. Well he's Mr. Clean! lmao
Well if Mr. Clean says it is CLEAN it MUST be so ;)
Looks great!
We so need a GJ run this fall. I call leading 21 Road! Yeah right!
