1 - 15 of 15 Posts
I have a 2003 Tacoma 2.7 liter. I have 3 drive belt pulleys on the crankshaft. The most rear one had the harmonic balancer built into it. The pulley part of it came off and broke loose. I have to get the crankshaft pulley bolt out. Mine has an automatic transmission so I cant put it in gear and break the bolt loose with a breaker bar. I have to do it different. I am thinking of doing the breaker bar thing where I put a braker bar on it and then resting the end of the bar on my frame and then bump the starter. Any of you guys confirm that this works ? If so tell me more about it. Plus I would like to know if the first two pulleys come off without having to take the crankshaft bolt out ? I did take out the 4 small bolts. Any help is really appreciated .
Shut the engine off with it in drive and do it just as you would with a manual in gear and the E-brake on and wheels chocked.
You can use a chain wrench around the pulley & a big breaker bar. Just remember, once that crank bolt has been taken off, it MUST be replaced w/ a new bolt.
Sent from my Nexus 6 using Tapatalk
Why a new bolt ?
Why a new bolt ?
It's a fine pitched thread & it stretches. Trust me on this, it's cheap insurance. My 96' Tacoma's 3RZ shit the bed after I had the front main replaced. It was torqued properly & backed out about a wk later. The HB backed off the oil pump & toasted my pistons.
Does anyone know if the other two pulleys in front of the rear one will come off while the crankshaft bolt is still in place ? I have taken off the 4 small bolts and the two front pulleys are still tight on there and won't come loose
Ok I just the crankshaft bolt and puleyy off . Thank God ! I can barely see the woodruff key or whatever you call that half moon key or pin . It look great but I'm scared if I take it out I may not get the new one in. It way far back in that hole . Is it used to drive anything else other than the pulley ?
Do you guys think I should replace the crankshaft seal while I am there ? They are only $8 and doesn't look too hard to replace . I think they just press inward with a large socket and a hammer .
You aren't gonna disturb the key. The other pulleys can remain bolted to the crank pulley, it'll all come off as 1 unit. I'd just replace the seal & the bolt... both are cheap insurance & you're already that far along.
I'm going to bet in your case the bolt didn't get torqued correctly. I'm running on 100k+ miles on my current engine after I swapped the crank pulley. No issues with the bolt backing off.
Discussion Starter #12
Ok , I just got my crankshaft pulley holder made. When I was buying the bolts , I was at a specialty store that handle only bolts and fasteners. The guy asked me how much torque I was gonna use. I said between 193 and 217 Ft. Lbs . He said that was way too much. I said that was what is needed. I even went by Toyota and they showed 193 Ft. Lbs on the 2.7 which is my engine , and 217 Ft Lbs on the 3.4 V-6 . The bolt guy said that would break the bolt. He said that only around 50 lbs or so was only needed and that I got Ft Lbs and inch Lbs mixed up. WOW . I just smiled and said thanks and went on.
Discussion Starter #14
You'll probably bend those bolts in the process, but hopefully the tool will hold up.
Best not to take advice from that hardware guy. He doesn't have a clue what he is talking about. :eek:
The bolts are the hardest and highest rated ones so they should be good. I made this based on a friends tool he made. The bolts are M8X1.25 Class 10.9 . They are strong .
NorCal Chapter Pres
He probably meant 50 ft lbs on those bolts...
Sent from my SM-G920V using Tapatalk
1 - 15 of 15 Posts
