1 - 20 of 37 Posts
Well I can't find any bolt on pre-made mounts for cheap (less than $15.00 a pc) and I have some 7"x5" 1/4" steel plate laying around so I'm throwing something together -
Are you guys bending the 1 pc plate into the L shape with an oxy/acc torch and a vise? This was my plan, I wasn't sure if this would weaken the mounts though. (dick's instructions didn't state how/if he bent the plate)
Then after bending 1 pc into an L, welding the back plate to complete the U shape around the frame -
Thanks -
Trevor
Thanks -
Trevor
I was fortunate enough to have a brother that works in the steel fabbin industry for buildings. He bent them for me...
If I had to do it, I would weld two plates them grind them flat. Would be easier to get then angle than using a oxy acy with a vise.
X2. Its going to cost less too! Probably less time trying to make the angles smooth. Weld both sides and it'll be strong enough.
Contact DeMello Offroad.... he sells DIY stuff. Not sure on prices though.
You might be able to find some angle iron that has the right dimensions...
Well, dicks mount incorporates the tranny x-member. Very good design.
No angle iron out there can be made. It's like a 30* angle...
For the supports that wrap around the frame, I had my brother bend a L bracket, then I welded a plate on the end of it to complete the U. Only weld on one side, make sure the weld is good!
I would only bend the L if I knew that it was going to be at the correct angle and the inside radius would be tight.
Only weld on one side?:confused: One side of the plate? Like inside/outside?
If I did the l_l rather than the Ll you think that would be fine strength wise??
Trevor
All depends how good of a welder you are :p
If you weld the inside, it doesn't set itght against the frame. Besides, it's so narrow you can't get a mig gun or a stick in there to weld it...
Right, just weld the outside of the plate. Taek it on the truck, bolted in place, unbolt then weld.
I think it would be find stregnth wise. What I did it made the metal about 1/4" longer and used a fillet weld to join the two plates. Very strong.
Just cut and weld everything. I tried to bend the "L" shape, but bending with a vise and torch doesn't yield the best results and I didn't have acess to a big enough brake. Might take a little more time welding, but hey, welding is fun!
And I didn't like the idea of using the tranny mount as another mount, so I just made 4 "U" shaped mounts, incase I get rid of the stock mount.
I just cut out the plates and welded the 'Us' together. leave at least a 1/16" of 'play' in the U for shrinkage when you do the final burn. ;)
i remember seeing some bolt on mounts from cbi in a thread a while back they were 13 bucks i think pm them,im sure they have some pics
I just bought a the Rock Slider Mounting 8 leg Kit from WabFab for $24 plus shipping. These are actually Trail-Gear's, which I didn't know until they arrived.
Here's a pic. They come with the mount and gusset. I cannot get close to building these in CA for this price. The metal alone is more than $40.
Thanks -
Trevor
How those working out for you Anthony? :D
:welder:
If you've got a table saw with a metal cutting blade you can set your saw to cut about half way through the plate, then use your vice to bend it. Once you've got it where you want it, weld a bead on the inside of your cut.
It's the easiest way that I've found to bend plate.
Not sure what size exactly you are looking for but sometimes you can find odd size rectangular tubing as drop at your local steel supplier and cut one side off and have a nice "U" shaped bracket. I've made several brackets this way. Just another thought/option.
:welder:
:welder:
X2 Wab. I feel very lucky to have a big metal brake at work. Takes all the guessing out of the job.
They are going to work out great, but I have a baby due this week ( actually last Saturday ) and all my projects are on hold until who knows when. When I'm done I'll send you some pics.
Thanks!
AC
:welder:
Discussion Starter · #17 ·
Thanks guys - I think I'm just gonna try to build the U's myself. Just to make sure I'm seeing things correctly - Those CBI's are about $15.00 PER Mount right? I got my 1/4" plate for $2.00 a piece:confused: (I guess add some grade 8 hardware and it raises a bit)There is another 1/2 pallet I could go pick-up.
And yea - I look forward to the welding part :welder:
I finally received my 220v Hobart today.....Now I understand why everyone reccomends the 220v's over the 110's.....The voltage selection is unbelieveable....and waaay cleaner than my 110v.
Trevor
Ooops! Sorry, I somehow skipped over the part where you stated you wanted a U shape.. :eek:
Trevor
Discussion Starter · #19 · (Edited)
Also - Since I'm doing bolt-ons, it looks like the wafab/tg won't work? The bottom plate doesn't like like it goes all the way to the other side of the frame? (anyone confirm?) if so - yea, that's a great price.
Trevor
EDIT - Yea, U shape for bolt on's
Yes, you are correct. The frame channel is wider than the bottom plate. Well, at least on my 06..
Trevor
1 - 20 of 37 Posts
