I need to get new wipers soon. I have the factory Toyota wipers, but they don't seem to cut it in the snow and ice. Has anyone found a good set of wipers for the Tacoma that work well in the snowy, icy conditions of northeast ohio?
I'm from michigan and I have found that the cheapest wipers you can get from wal-mart are pretty good, and if they get destroyed then so what, your only out 3 bucks instead of however much it costs for the more expensive kind. Also letting the truck warm up and defrost the windows helps more than any wiper will on ice.
I currently have the Toytec 3'' lift with Dakar rear springs. This has allowed me to get by with 33''s, but of course they rub a bit. I am going to do a SAS coming up over the next couple months and was looking for a bit of advise. I know there are tons of threads on the matter, but I don't...
5VZ-FE Load Hesitation, Stutter, Sputter *SOLVED*
I've been chasing this engine stutter for about 1 week now. When parked if I rev the engine with more than 1/2 throttle it will sputter till about ~2,000 RPM. It feels like a misfire with out the CEL. The best way to explain it is a popping...
hello
i bought a used 2004 double cab auto with what looks to be an inchworm taco box with a 4.7 kit and inchworm adapters connected to a stock push button transfercase. i drained the first case and it looked like looked like a half a quart of redline gear oil. the rear case had two quarts of...
My truck seems to have a problem with the throttle at 2300 RPMs or below. If I accelerate slowly it bogs and sometimes will "pop". If I stomp on the throttle it runs fine.
Background: I had a rebuilt 2.7 motor installed in my 98 Tacoma Excab. The original gave out at 538k miles. While...
Is it possible at all?
So was wondering if there was a trick to quickly replace the thermostat without having to drain the whole thing.
How much coolant would it spill out if disconnecting hose from old thermostast without draining radiator?
Is it worth the try? Too messy?
Parking on the...
