1 - 16 of 16 Posts
since when does fabtech make a 4"?
typer0149 said:
can I fit any 35"s on there or should I stay with 33"S
also if I do a 2" body than can I fit 35"S
the general consensus is 33"s are about the max you can go with approx 4" of lift. they'll still rub a little off road - you'll need about 6" to clear 33's with no worries....
pro comp says that 32" is the max tire height for their lift (and it's a 4 inch suspension lift)...
search around in this forum and you'll find all kinds of people running all kinds of tire sizes, with all kinds of lift heights. it's a matter of how much you're willing to cut.
thats what I thought about fabtech lift
I will show everyone pics of it so you guys can let me know
you can run as large as 37" tires without trimming any body metal, if you don't mind driving in a constant straight line.:D
With trimming you will be able to run 35"
as said no triming~ 6" for 33"s and less run 32"s
you would easily be able to fit 35's if you did a 2'' body lift.. It only makes mathmatical sense. Since the truck has no rubbing issues with 33's, then if you add 2 more inches of lift, then you could add 2 inchs of tire
going from a 33" tire to a 35" tire is only a 1" difference in Diameter!! Each inch of tire only will add 1/2"... ;)
that makes mathmatical sense... :D
52s ...with some trimming ;)
NorCal Chapter Pres
der der derrrr
I've seen plenty of 'rubbing issues' with 33s and a 6" lift ;) It all depends on what sus system you have, bs on the wheels and how hard you hammer it.
NorCal Chapter Pres
Alignment too. I would rub on my old truck with a 3" and 32's on the stock aluignment. I'm running 2.6 now with 32's that are slightly larger, and with a alignment that has the caster low so the tires are up. I could hammer down on the truck and not rub, while my old truck would barely rub on the pavement...
Same rims, same everything...
1 - 16 of 16 Posts
