1 - 3 of 3 Posts
If your running Bilstein 5125's with 10" travel in rear, did you go with the 170/60 or 255/70 valving?
Thanks for the comments!
I'm running 7100's with 170/60 and wouldn't change a thing... Oh this is with quite a bit of extra weight both gear and flatbed/cage...
Later
Joel
I'm running 255/70 on my DC SB. I just switched to the 10" 5125's. I had 8.33 inch 5150's before in the same valving. Rides fine, but I have to either extend the bumpstop, or relocate the upper shock mount. It's close to bottoming out at full compression. Keep in mind that I have an 05.
1 - 3 of 3 Posts
